7 members (R&S 51 GMC, Otto Skorzeny, crenwelge, Hotrod Lincoln, 1955 1 Series, Tronman, Wrenchman),
194
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,125 Posts1,056,341 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 24 | Can anyone tell me how much work it would take to fit a hood from a 58 Chevy truck onto a 57 Chevy truck ... or are the differences so great it isn't worth the trouble. I'm asking since I prefer the look of the 58 hood. Thanks
Two 1957 Chevy Step Sides 1988 Fiero Formula 1987 Fiero GT 1984 Fiero Indy ... yes I like Fieros also.. ;-)
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the 58 hood is a different curve down the sides to fit different shaped fenders [wider dual headlights] - the hinges are different, mounting to both the firewall and the inner fender and the hinge springs attach to a bracket on the inner fenders ... just won't work unless you put the whole 58 doghouse on .... and then the mount holes on the firewall would need some fudging and you'd find the 57 frame was too short to install the lower splash pan  simplier answer - I measured for ya, the 55-7 hoods are 41.5" across the front, the 58/9 is 37.5" Bill
| | | | | Joined: Mar 2007 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 24 | Thanks a lot Bill.
Is there much of a market for really nice 58 hoods (no rust) or should I just return it to the salvage yard in your opinion?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | hoods aren't a high demand item seperate from the truck or doghouse
Bill | | |
