5 members (Wally / Montana, LAROKE, kades51, greenie-reddy, 1 invisible), 70 guests, and 4 robots.
Topics128,185
Posts1,057,281
Members48,467
Junior Member
Junior Member
Hello! I'm new to this site and it looks like I'm going to be spending quite a bit of time here. So here's my first question:
I have a 69 gmc C1500 with a 307/3 spd on the column. I acquired a 1969 gmc 2500 with a TH400 that I would like to put in my 1500. Has anybody here done this before? It appears to be a straight-forward swap, but I would like to hear if anybody has had any problems with a similar swap.
With the automatic-equipped truck as a donor vehicle, you shouldn't have much trouble. You'll need to swap such things as the radiator, rear crossmember, steering column, and a little wiring, since the TH 400 has an electrically-triggered 3/2 downshift. The front driveshaft spline will be different. As long as both trucks have the same wheelbase, the driveshaft for the auto should swap without a problem. If the wheelbase is different, you'll probably have to have it shortened or lengthened by a driveline shop.
1 Offline
One problem I had when geting my 69 C10 ready to convert to an automatic is that the 3spd crossmember is rivited to the frame and may be a real bear to remove with the engine in the way. Otherwise the swap should be straight forward
Sean
doing what you love is happiness
loving what you do is freedom
Sean-
You may also want to give some thought to a Power Brake swap after you install an automatic, even at idle your leg will get tired from holding enough brake pressure to keep the truck from rolling.
Good Luck!
Guy
1 Offline
Guy-
My friend I bought my truck from has a 72 Super Cheyenne that he told me he had swaped all of the later 73-86 suspension including the control arms on to. So a guy I work with was parting out a 73 C10 that had a cab fire, he torched the frame off at the fire wall and gave me everything including the brake booster off the firewall and the power steering. I am also planning on installing a 700r4 that I rebuilt, if I ever finnish the rust repair. Bessie looks great.
Sean
Junior Member
Junior Member
I didn't think about the power brake swap. But I know what you mean and its sounds like a good idea. Maybe I can just adjust the idle down a little instead. I'm going to start the trans swap soon. I'll post updates on any problems I have.
