| | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70682 12/27/2006 11:52 PM | Joined: Dec 2006 Posts: 4 Junior Member | | Junior Member Joined: Dec 2006 Posts: 4 | Hello! I'm new to this site and it looks like I'm going to be spending quite a bit of time here. So here's my first question: I have a 69 gmc C1500 with a 307/3 spd on the column. I acquired a 1969 gmc 2500 with a TH400 that I would like to put in my 1500. Has anybody here done this before? It appears to be a straight-forward swap, but I would like to hear if anybody has had any problems with a similar swap. | | |
#70683 12/28/2006 2:57 AM | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | With the automatic-equipped truck as a donor vehicle, you shouldn't have much trouble. You'll need to swap such things as the radiator, rear crossmember, steering column, and a little wiring, since the TH 400 has an electrically-triggered 3/2 downshift. The front driveshaft spline will be different. As long as both trucks have the same wheelbase, the driveshaft for the auto should swap without a problem. If the wheelbase is different, you'll probably have to have it shortened or lengthened by a driveline shop. Jerry
#70684 12/29/2006 2:01 AM | Joined: Dec 2006 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 65 | One problem I had when geting my 69 C10 ready to convert to an automatic is that the 3spd crossmember is rivited to the frame and may be a real bear to remove with the engine in the way. Otherwise the swap should be straight forward
Sean
doing what you love is happiness loving what you do is freedom
#70685 12/29/2006 4:41 PM | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Sean- You may also want to give some thought to a Power Brake swap after you install an automatic, even at idle your leg will get tired from holding enough brake pressure to keep the truck from rolling. Good Luck! Guy | | |
#70686 12/30/2006 5:00 AM | Joined: Dec 2006 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 65 | Guy- My friend I bought my truck from has a 72 Super Cheyenne that he told me he had swaped all of the later 73-86 suspension including the control arms on to. So a guy I work with was parting out a 73 C10 that had a cab fire, he torched the frame off at the fire wall and gave me everything including the brake booster off the firewall and the power steering. I am also planning on installing a 700r4 that I rebuilt, if I ever finnish the rust repair. Bessie looks great.
Sean
#70687 12/30/2006 8:44 PM | Joined: Dec 2006 Posts: 4 Junior Member | | Junior Member Joined: Dec 2006 Posts: 4 | I didn't think about the power brake swap. But I know what you mean and its sounds like a good idea. Maybe I can just adjust the idle down a little instead. I'm going to start the trans swap soon. I'll post updates on any problems I have. | | |
