1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | I was reading the thread about the HEI ignition and the recommended gaps were anywhere from .045 to .060. Is there a point on a gas engine that is too much? The reason I wonder is, that on a propane engine you should run around .025. I had a 318 Chrysler with electronic ignition on an irrigation pump that I fought for years trying to get it to start and run right. It always started hard and always seemed to have a half ways miss in it. I can't tell you how many ignition components I changed trying to get it get it to run right. I was running about .045 on the plugs. I thought the wider the gap, the better. One day, out of frustration I called probably the second best mechanic in the county and he asked what the plug gap was. I told him, and he said it was far too wide for propane. He recommended .025. It made a whole different engine out of it. It started instantly, sounded perfect at all rpms and loads and took less fuel. He was truly an excellent mechanic. He could tell by looking at the plugs almost anything that was wrong with the engine.
He died 2 years ago coming up in June. I sure miss that guy. As good as he was as a mechanic, he was even better as a person.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Im using the pertronix set up on my 1950. 235 12v, They recommend .005 over factory. As did other members on this forum when I posted a similar question. I have them set at .040 now. Good Luck | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Chev. specified .045 with their HEI ign. The Petronics uses stock or near stock coil & the plus.005 sounds right. If you get too much gap it is easy for the spark to leak out before it gets to the electrods. Some GM cars used .060 & .080 gaps & had starting problems in cold & damp weather. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | we are running a Langdon HEI unit in a 1957-235. We followed Toms advice as to the gap and type of plug. What we don't know (never having an HEI unit) how many miles before we need new plugs? The plus in my wife's car will go 100K before changing!!
Thanks for the advice and Happy New year to all!
Steve | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Spark plugs last a lot longer then they used to because the no lead gas does not have the erosion effect the lead had. We used to replace plugs on these old trucks about every 10,000 miles. You can't run them 100,000 like the modern car's though. About 25,000 would be about right. You can inspect 1 or2 at random occasonally & check for foriegn deposit buildup & erosion. If they are OK keep going.
Last edited by Wrenchbender Ret.; 12/30/2010 9:52 PM. Reason: Left out the T in can't
