3 members (Donf, rfs56trk, 1 invisible),
130
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 36 | There is about a two inch area around the grill that is sometimes painted white and sometimes painted the color of the vehicle. I've seen just as many one way as I have the other. So my question is, which way did it come from the factory, or did it come either way. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What year, make, nodel? Chrome or painted grill? Can you post a link or two to photos in the Gallery? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I got 2 64's, one green/ivory one light blue/ivory-both had the white stripe around the grille area.
The all-ivory '64 truck did not. | | | | | Joined: Sep 2001 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 36 | Thanks 64fleetside, after doing a little more research it does appear that the 60-66 trucks came from the factory with the white stripe. I see a lot of newly painted vehicles where that detail is somehow overlooked. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i always thought if they were painted the same color as truck it was a repaint. it seems to make the grille pop out better, but i have to admit on my 63 and 64 i didn't do it when i painted them. | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | On the 60-66 trucks depending what make and model it was they all came with white on them. If you ordered a top of the line model they came with all the stainless pieces. I remember if you ordered certain inside cab accesseries back then you got the Grill,Cab side plates, Eyebrows etc. in stainless. 62Blue. Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The Off-White accent around the outer circle of the grille support, was standard on all light-duty Chevy trucks from '60-'66, with the exception of the trucks, that were painted White. The backdrop of the grille support was painted Black in semi-gloss sheen. This information is pulled from the Truck Sales Data books from '60-'66. | | |
