6 members (Shaffer's1950, Otto Skorzeny, Gdads51, Wayne67vert, Hotrod Lincoln, ‘37ChevyPU), 98 guests, and 1 robot.
Topics128,139
Posts1,056,454
Members48,441
#706542 12/27/2010 12:53 AM
Hi guys I need to change out the glove box latch that mounts in the dash. It looks like it is a press fit. Is that correct. I want to find out before i take a hammer to it. I have the replacement and I don't see any other way it attaches and there is nothing in my manual, Thanks........steve
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=697448#Post697448
My 50 has a small clutch head screw on the back of the latch assembly that I had to remove.
Good luck
My 52 has the same setup. Small clutch head screw in the back of the latch housing. Take that out, then you can wriggle the housing off of the lock assembly.
