0 members (),
83
0
Mod | | | Forums66 Topics128,108 Posts1,056,566 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70639 12/27/2006 2:57 AM | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | Is the two piece dust cover for the bellhousing on a 1/2 ton truck the same as a 3/4 ton truck? (I'm missing the front piece and there is a 3/4 ton in the local junk yard.) Thank you! [email protected] | | |
#70640 12/27/2006 3:15 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | |
#70641 12/27/2006 3:15 AM | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | if the motors are the same, the dust covers will be the same. IE: 6 cyl. 235,216,261. etc,,the motor doesnt know if its in a 3/4 ton or 1/2 ton. | | |
