3 members (Wayne67vert, Otto Skorzeny, stlcardinalsguy), 69 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#706116 12/24/2010 7:03 PM
Members:
I have stripped my motor for painting and now have to put everything back on....Before I go searching all thru the manual. Has anyone of you put together a Torque sheet for a 235 motor ? I have done this in the past for Harleys...makes it easy to have all the info in one spot....which isn't in my brain.
I'm working on .oilpan,diff. cover,valve cover,side cover,water pump, thermostat to block, thermostat, timing cover,fuel pump, starter etc....
Thanks Guys.
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
Jimmi_V #706134 12/24/2010 8:49 PM
Most manuals have it all on one page.
Jimmi_V #706139 12/24/2010 9:00 PM
I torque the head, mains, and rods; every thing else by feal. The manual might give a value for the water pump, starter; don't remember seeing anything on the 1/4" stovebolts or cap screws
WillH #706142 12/24/2010 9:08 PM
Cylinder head 95
Mains 105
Rods 40
Flywheel 60
Rocker arm 30
Bell housing 50
My Blog
As Cletis said, the manuals have most of the torque values on one page. This is from the 1949-53 car manual. If this is not for your engine. look through the other manuals in Keith Hardy's old OLD ONLINE CHEVY MANUALS website.
Hoyt
hoyt #706186 12/25/2010 12:39 AM
Thanks guys, since I have a 53 car motor in my 54 3100, I guess I should get a 49-53 car manual.
Hoyt, that is exactly what I was looking for. I couldn't find that in the 54 truck manual...I saw specs in each chapter but not all together like that....BUT, doesn't mean it's not there....Could mean I just could't find it.
Jimmi V.
Jimmi_V #706226 12/25/2010 3:40 AM
Since you already have a '54 truck manual I'd suggest getting a I'd suggest getting a Motors Manual for the car specs.
Cletis #706327 12/25/2010 6:11 PM
Thanks Cletis, didn't know I could get a motor manual only...
Jimmi V.
Jimmi_V #706336 12/25/2010 6:29 PM
Jimmi, that's Motor'S Manual
