| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members:
I have stripped my motor for painting and now have to put everything back on....Before I go searching all thru the manual. Has anyone of you put together a Torque sheet for a 235 motor ? I have done this in the past for Harleys...makes it easy to have all the info in one spot....which isn't in my brain. I'm working on .oilpan,diff. cover,valve cover,side cover,water pump, thermostat to block, thermostat, timing cover,fuel pump, starter etc.... Thanks Guys. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Most manuals have it all on one page. | | | | | Joined: Oct 2010 Posts: 45 New Guy | | New Guy Joined: Oct 2010 Posts: 45 | I torque the head, mains, and rods; every thing else by feal. The manual might give a value for the water pump, starter; don't remember seeing anything on the 1/4" stovebolts or cap screws | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Cylinder head 95 Mains 105 Rods 40 Flywheel 60 Rocker arm 30 Bell housing 50
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | As Cletis said, the manuals have most of the torque values on one page. This is from the 1949-53 car manual. If this is not for your engine. look through the other manuals in Keith Hardy's old OLD ONLINE CHEVY MANUALS website. Hoyt
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Thanks guys, since I have a 53 car motor in my 54 3100, I guess I should get a 49-53 car manual. Hoyt, that is exactly what I was looking for. I couldn't find that in the 54 truck manual...I saw specs in each chapter but not all together like that....BUT, doesn't mean it's not there....Could mean I just could't find it. Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Since you already have a '54 truck manual I'd suggest getting a I'd suggest getting a Motors Manual for the car specs. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Thanks Cletis, didn't know I could get a motor manual only... | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Jimmi, that's Motor'S ManualBill | | |
