1 members (Shade Baby),
58
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I recently acquired a Carter YF 966S carburetor. The metering rod jet is marked 120-162. One of Carb King’s old postings stated that the last 2 digits of this number is the orifice size of the jet in thousandths on the YFs. So then it would be a 0.062 orifice. The low speed jet assembly has 11-325 stamped on the head (At least I think it does, it is hard to read). I’m not sure if this is a part number or this number can also be used to determine the size of the jet.
I’m not familiar with the correct size of the YF jets for a Chevy 235. I live on the coast in So. California. I’m just wondering if these jets would be either too lean or too rich. I’m not that well acquainted with the Carter YF.
Thanks. Mark
| | | | | Joined: Nov 2002 Posts: 2,782 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,782 | You need to re-read the source.
The last 2 digits are the size in thousandth IF AND ONLY IF the part number is 120-350 OR HIGHER. This does not apply to jets 120-349 and lower. Then the number is just a part number with no additional meaning.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Thanks Jon. I appreciate it.
Mark | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | 966S
Low speed jet assembly part # should be 11-232S. Low speed jet tube: Jet size No. 67 (.032 inch) drill.
The metering rod jet is .1015 inch diameter. Standard metering rod - part # 75-838. Metering rods also came in 1 & 2 sizes lean.
If you're lucky enough to find an old repair package, #1742, jets and metering rod were included in the kit.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Thanks for the info. I like the Carter over the Rochester B. The 966 that I have is in fairly good shape with the exception of some parts that I could get in a kit. Finding replacement jets maybe a challenge. | | | | | Joined: Nov 2002 Posts: 2,782 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,782 | All parts other than the castings are readily available.
The stock configuration was used by Carter from sea level to 4000 feet; although today with E-10, it may be a bit lean.
