Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Crimson48, TUTS 59, Phak1, Gdads51, 1 invisible), 48 guests, and 0 robots.
Topics128,007
Posts1,055,278
Members48,418
#706067 12/24/2010 2:52 PM
Y
Y Offline
For those of you that have installed the firewall booster, what are you using for a brake light switch? This is on a 57.
Have you mounted the booster on the firewall yet ? If so what mount and peddles did you use?
1937 Chevy 1/2 ton panel
I made an "L" bracket mounted to the steering column that holds a standard 60's-80's GM stoplight switch -- threaded plastic body, plunger kisses the brake pedal arm. S237 (2 term) or S299 (4 term) Borg Warner IIRC. I'm using 4 term now with cruise.
