| | | Forums66 Topics128,100 Posts1,056,178 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 16 | Is the steering column identical on a floor shift and on a column shift. I'm wondering because I have a steering column out of a truck that had a floor shift 3 speed and want to make it a 3 on the tree. Will I have to acquire another steering column. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | The factory ('48-'53) columns that had 3 on the tree differ from those that had a factory 4spd floor shift. The difference is the columns for the 3 spd had 2 threaded holes up close to the steering wheel for the shifter bracket to bolt on. And, there is an elongated hole just above the steering box where the shifter control box would be mounted. The factory 4spd ('48-'53) columns don't have these holes. If your column is out of a '47 truck, both the 3 spd and 4 spd were floor shift. The '54 columns are a different length. They differ by about .50"- .75" in length. | | | | | Joined: Oct 2010 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 16 | Really? Is the 54's shorter or longer?
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 |
-Tom
1950 Chevy 3100 w/ 1956 235
