| | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | hello all, So i have a 51 deluxe half ton doing a complete frame off restoration...taking my time...been 17 years and counting now. Anyways, I have heard i can use my stock rear axle housing, just need to unbolt the stock pumpkin and torque tube, reinstall a pumpkin out of a another half ton up to 1962ish?? My question is, i want to keep my stock 3 speed on the column. what do i need to do for a replacement driveline? do i need one made or can i go wrecking yard shopping? please help! jeff | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | well, you can keep the torque tube and the 3 speed and the rearend, only if you keep it the way it is, or change the gears to a 3.55. If you want to move to an open driveline, you will also need a new transmission. The later open drive 3 speeds will likely be able to fit your bill. You may have to modify the linkages, however. | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | thanks for the info. wasnt sure if i could use the stock 3 speed with a open driveline. its been 5 years since i last saw it in my shed. finally have a garage to restore my baby since 1993! | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | new question i guess. what year did they ditch granny low in the 3 speed? say if i found a 60's 3 speed. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Granny low was on the 4 speed, not the 3 speed trans. | | |
