| | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | I have the cab to my 51 3600 in the garage on saw horses. I removed the doors, and the windows and then thought about cross bracing the cab. Has anyone else done this? Am I in for trouble aligning doors and such when I go to put it all back together? Any suggestions? Of course I want to hear, don't worry about it! But what I really want is to do is the best I can given what I have. Let me know what you think. | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | I can't see there being a problem, unless its really rotten in the floors and rockers. If its solid, these guys pick them up by the roof all the time, so shouldn't really be an issue. Even without the doors, the cab is a pretty substantial structure. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Rick,as Andy has already mentioned,if your cab's reasonably solid,you should be OK. If,however the cab has rot around the floors,cowls,rockers etc, and I assume by the fact you want to brace the cab,this might be the problem,personally I would re-fit the doors,set the gaps as best as you can and THEN brace the cab. That way when you refit them after welding the cab,they should still fit the aperatures.JMO 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 55 | I did this with many of the cabs that I've had. Even after removing the cab and setting it on a homemade stand that I could roll around the garage. Because I had to do a good deal of welding on the floorboards and replace BOTH rocker panels, I took a piece of 1/4" angle iron, measured the opening of the door area, made sure it was the same on both sides, then tack-welded the angle iron in place on the front and rear of the door openings. After being that way for more than a year (I'm a slow worker)  after getting all of the welding done, removing the angle iron, both doors hung easily, and IMHO, perfectly! | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I would strongly recommend against any "major" parts replacement with the cab off the frame. Your frame is like a fixture and since that's where the cab will wind up in the end it's a LOT better to know it will fit when you're finished cutting and welding than to find out the hard way when you try to put it back on after working on it off the frame. When you get it all welded back together and you know your doors fit with it on the frame THEN pull it off and put it on the dolly for cleaning and painting. I never took mine off the frame. Even when I was done with the surgery part I just rolled it back on the frame to get access to the bottom. For pix, start HERE and hit the NEXT button a few times to see what I did. There was a guy here some time ago who did it off the frame and he had some major horror stories to tell. | | |
