1 members (Paul Mullen),
109
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70569 12/25/2006 10:34 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I have a '54 GMC with a Chevy engine in it. I just received a "new" radiator support and I figured out why the PO torched the bottom off the old support. The radiator thats in the truck wouldn't clear the bottom of the support. This is a 235 in a '54. The radiator appears too tall(total height appx 29")? If I buy a new radiator, (it has to fit in front of the support) what should I get? I need to be sure the new water line (to the block) won't hit the fan.
Also, how do you visually tell the difference between a 235 and 261?
Thanks for any help. | | |
#70570 12/26/2006 3:49 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | 261 has captin's bars and water pump lower on block...doc | | |
#70571 12/26/2006 8:55 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks, Doc. Can someone here give me the total height of their radiator?
Thanks. | | |
