I changed the heat spacer under the carb and two gaskets .I went to my stock pile of parts to get them .The width between the two mount bolts is the same as a 235 ,checked my Dad's 235 fit's .My question is are the manifolds different on the larger trucks 1953 4400 ?I did check the engine # everyone says its a 216 looks like and 216.I have rebuilt many of these engines 216 and never seen this !
ID ON ENGINE BLOCK IS LCD28908I
