6 members (homer52, TrknGMC, Ponchogl, klhansen, Robert Crandall, Hotrod Lincoln), 37 guests, and 3 robots.
Topics128,023
Posts1,055,371
Members48,420
#705481 12/22/2010 5:08 AM
I'd like to know what is a good year/make/model frame would be a good choice to put under my '53 GMC 5 window?
I'll bet a '53 five window frame will fit best!
Anyone want to second me?
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
andy46 #705489 12/22/2010 5:21 AM
I will! thumbs_up
Bill Burmeister
Me too.
andy46 #705491 12/22/2010 5:23 AM
haha Obviously but im in the process of an off frame restoration and im considering just finding a rolling chassis with engine and tranny to drop it on and use the original frame for another project i have in the works.
well thanks for the lack of help guys!
Sounds like you have gotten plenty of help and good advice so far.
If it's not what you wanted to hear try throwing in some more details about your plans and ask the question again. Might get the same answer though...
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Well you might want to give people a little time on this one.
If your into a serious rod type rebuild then grab the Feb 2011 issue of StreetRodder magazine, they have a big section on rolling chassis in that issue, and some real nice stuff.
1946 Chevy 1/2-Ton
andy46 #705505 12/22/2010 5:59 AM
That sounds like a plan thank you i'll check it out. i guessed i just assumed somebody else might have considered switching out the frame and had a suitable donor that worked for them
no doubt a few out of the 25 thousand members here have considered most anything imaginable wink
some searching in the HiPo threads might give you some food for thought about major modifications
A "restoration" does not use a different frame. You got good answers to your original question.
Looks like you are wanting to rod the truck. You'll get answers for that in the Hipo Shop.
By the way, welcome to the forums.
You need to tell us a little about what your plans are. There are several modifications that can be made depending on what you decide you can live with.
Are you planning on restoring it? If so the original frame would be the correct one to use.
Are you planning on using a six cylinder? GMC 228/270/302 sixes are longer than the Chevrolet 216/235/261 engines
Is this going to be for freeway use?
Are you planning a low budget build?
Are you thinking about making it into a Rat Rod?
Are you planning on using it as a daily driver?
Do you plan on using it as a tow vehicle?
Do you want to keep the original suspension, torque tube driveline?
I have seen the AD body on a 1987 4x4 frame (Wheels poked out)
I have seen a 1990 Chevrolet 1/2 ton frame used. Modern suspension with power steering and disc brakes
I have seen them on a S-10 frame (kits available) air bags will work on this frame to give you that slammed look.
I have seen Volare independent suspension welded to the original frame
I have seen a AMC Pacer front suspension welded on the original frame
A fellow bolter sells an independent front end kit to attach to your original frame
Are you considering installing a flat bed? If so that opens up lot's of possibilities on other frames since you control the length of the frame and bed.
There are great after market frames that would give you a very nice start to a beautiful hot rod.
GMONIZ #706496 12/26/2010 8:44 PM
Ter Offline
I am doing a flatbed - AD cab and fenders with a 2007 Dakota 4X4 frame and it is not easy. I would suggest an S10 frame... much easier fit. I agree with GMONIZ above
Ter #707644 12/31/2010 2:25 PM
hay i agree your orginal question was answered no need to get smart but thay are a few of us that mod trucks to far gone to restore a 80s or 90s s=10 frame works well with a ad engineering kit to answer your question next time give more details.
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
squeeze #707993 01/01/2011 9:37 PM
Hi I have a 53 big truck 4400 body on a lowered 86 chev dually chassis (allot of fabricating needed) .I helped a friend a few years ago who mounted his 49 on an S10 frame that went very well and the track width looked correct without sticking past the fenders .The biggest issues were all about fabricating mounts that put the body on level, as the frame is not as straight as the original. It was very economical as there are alot of kits to put a small block in the frame,you get great ride and steering,as well as much better brakes all for less than an independent front end kit alone would cost.
PKap #709684 01/07/2011 5:41 AM
hey pkap, where abouts are you located?
tyler h #710066 01/08/2011 5:44 PM
Im located about half hour west of Edmonton
