2 members (Steelonsteel, Hotrod Lincoln), 136 guests, and 4 robots.
Topics128,109
Posts1,056,261
Members48,439
I am restoring a 1958 chevy apache with only 105,000 original miles on it. The only thing not original however is the rims. Can anyone tell me where i could find some. Or what years will fit and accept the original hubcap.
If you post in the parts wanted forum, you might get what you need from another bolter.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
Welcome to Stovebolt! I beleive '57-'60 wheels should work, those years all used the same hubcap. One thing that might help in your search, though, would be to list what size truck you're working with, 1/2, 3/4, or 1 ton.
Bill Burmeister
1/2 Ton '58's had 15" and 16" wheels. 6 hole bolt pattern. The proper wheel will also have 3 tabs rivited to the rim that hold the hubcap on.
I just re did my 15" wheels, I found 4 of them on craigslist from someone that was making a hot rod. I had them sand blasted for $100, and new whitewalls from Tucker Tire for $480.
Key to the old rivited rims, is make SURE you clean the rivets well, and coat them with a sealant on the inside of the rim, before the tires go on. That will help them from the inevitable slow leak. I used a marine sealer. (3M 4200)
Good luck!
1958 Chevy Apache Fleetside/235/3 sp
Pictures at http://www.facebook.com/album.php?aid=317454&id=855355703&l=0a0f773195
