| | | Forums66 Topics128,018 Posts1,055,340 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70485 12/23/2006 11:04 PM | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | I have recently finished timing my 235, as well as putting in new points, condensor, and rotor. The engine runs fine and smooth at idle. If you gradually increase the RPM the engine continues to run smoothly. However, if you "blip" the gas pedal the engine "burps"--not really a backfire type noise, more like a burp from the engine bay. When it burps the engine hesitates and almost quits. Could this be a carburator problem? What do you think? Thanks. | | |
#70486 12/23/2006 11:16 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It sounds like a carb. problem. With the engine off look down the throat of the carb & move the accelerator. You should see a squirt of gas going in the throat. If not the accel pump may be bad. The float level might be low. Try advancing the spark a few degrees & see if it improves. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#70487 12/24/2006 12:13 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Greg,
Good advice from Lenexa...I would ask, is the engine warm when you try this? Even the best tuned rig can burp when cold. While poking around in there, make sure the vacuum advance 'flips' when you 'blip'. It should move as the carburetor is worked.
Stuart | | |
#70488 12/24/2006 12:37 AM | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | Yeah, the engine was cold--I tried blipping the gas right after I started it up. The good thing is that it seemed ok later in the day after we started it up again and let it warm up (it is fairly cold here now).
I don't understand why the engine temperature would make a difference in this case. The spark/timing is mechanically linked, as is the fuel pump. Why would it make a differnce if the engine was cold?
I probably jumped the gun with my original post, but I feel the need to understand why things happen the way they do. This is my first time working on an engine like this, and I don't have the luxury of experience to tell me what I should accept, and what is abnormal. Thanks guys! | | |
#70489 12/24/2006 1:35 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Greg, Since I am now on the plus side of sixty, I can appreciate being warmed up before being 'blipped'. My guess is that the fuel doesn't vaporize as well at the lower temperatures and won't mix as well with the air. The cold intake runners and associated engine parts tend to pull and sling the fuel out of the mix and things just don't work as efficiently until the rig is up to operating temperature. Stuart | | |
#70490 12/24/2006 7:58 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Not to mention the thicker oil and resulting tighter clearances in the engine are giving resistance,trying to keep the engine from picking up revs until it's warmed up. Speed | | |
#70491 12/24/2006 3:22 PM | Joined: Apr 2006 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 171 | Stuart and speed, your comments make a lot of sense. As I said in a previous post, it is sometimes hard for me to determine if something is wrong, or if it is just part of normal "old chevy character". In this case, I think I'm going to consider it part of normal "old chevy character", although I am now more motivated to purchase the manifold heat valve spring that I noticed was missing. Thanks for your thoughts! | | |
#70492 12/24/2006 3:31 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A cold engine needs a richer fuel mixture. If your accelerator pump isn't up to snuff the stumbling (burp) will be worse with a cold engine. The vast majority of cases of this type of problem I've experienced have been the result of a faulty accelerator pump.
#70493 12/24/2006 3:48 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If your engine hesitates & bogs when cold & runs fine when warm you have the ideal condition. That is the poor mans tuneup machine. That,s why they put chokes on them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
