11 members (Rusty Rod, klhansen, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 3800GUY, Oswald, Wally / Montana, 1 invisible),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70479 12/23/2006 7:47 PM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Existing situation. 1954 Rebuilt motor with a bellhouseing that was gifted to me from a friends yard. The bellhouseing has the three bolts for the 1946 pedel / clutch mount. Pedels mount correctly. With the recent posts its my understanding their are several bellhouseing that the 1946 pedels can mount to. How is it possible to tell which bellhouseing to use when installing a T-5 trannie. Car?, Truck? Motor mount type? My 420 trannie bolt pattern is not the same as the bell and am wondering if the adapter thats used for the T-5 is made for several different bellhouseing. Does this make sense? Thank you. | | |
#70480 12/23/2006 9:03 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The 37-40 bell housings were basically the same. The clutch fork ball was mounted further away from the tranmission hole on the 37-40. On the 41-46, the clutch fork ball was mounted closer to the center of the bellhousing. So even though both pedals mounted to the same three holes on the bell housings, and the clutch and brake pedal bracket are the same for all years, the set up is slightly different in the geometry of the pedal travel, especially the brake pedal. In other words, the 37-40 used a different clutch fork. Consequently, the 41-46 adapter made by Steve@Buffalo is not exactly correct for the 37-40, but I'm not sure Steve is aware of that. The adapter plate he sent me was a 41-46 adapter, but I made it work for my 37 by filing the hole out so it was larger and closer to the center of the adapter transmission hole. I would say, if you use the 41-46 TRUCK bell housing adapter plate from Steve@Buffalo, you will be on the right track. To ease you mind, a short conversation with Steve would be a good idea. Good luck! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#70481 12/25/2006 3:27 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | If you use a 41-46 bellhousing (truck), you will have to use an adapter plate like steppinwood did in his tech tip... installing a t5 in an art deco truck. If you use the the later bellhousing... 48-54, you will need to fabricate a pedal mount. This bellhousing will bolt up to the t-5, but you will need to do further modifications to the transmission to gain the appropriate amount of clutch travel. | | |
#70482 12/25/2006 4:07 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I would use a spacer plate rather than shorten the input shaft or extend the splines. That way you don't have to modify anything if you need another transmission. | | |
#70483 12/30/2006 12:00 AM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Did any of the bellhouseings after 1946 have the clutch / brake pedel mounting holes? | | |
#70484 12/30/2006 6:50 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Only the First Series 47 truck, which was actually a 46 truck. Joe
