2 members (Gdads51, Jon G), 100 guests, and 0 robots.
Topics128,049
Posts1,055,691
#704645 12/19/2010 3:54 AM
I have a 1965 custom cab short bed fleetside with a 283 and a powerglide transmission. In looking at parts catalogs they often refer to the dash either having lights or gauges. How can you know which you set up you have?
I think what they are referring to is Gauges or idiot lights. The lights are the ones that come on when oil pressure is low, or engine overheats, etc. Not everything came equiped with gauges except for speedo.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
Simple- if you see lights on your dash you have lights, and if you see gauges, you have gauges.LOL
I'm just being a smart-a$$. Welcome to the forum!
Check out this link http://www.persh.org/Pickup/interiors.htm#classic
Notice the Temp, Batt, Oil and Fuel gauges (pointer).
On the gauge clusters with the indicator lights the Temp, Batt and oil gauges merely have a light. You won't know if there is a problem until the light comes on, at which point you need to act fast!
Most people prefer gauges, which allow an "observant" driver to notice something different and fix it before it becomes a problem. But then again more than one motor has been destroyed by a driver not paying attention to the gauges. ohwell
6 of one, half a dozen of the other.
Hope this helps.
Thank you for the reply. I wasn't sure how to identify what type I had.
Thank you for the reply. I figured I had what is considered lights but I was not sure how to identify which was which.
answered my question as well..ordering a new 6volt harness works for 12v due to the 6v being heavier wire right?
62' GMC SWB Fleetside
Why can't we just go back to the designs from when cars were unique and didn't all look the same?
keilkravec - someone sells a 6V harness for 60s trucks??
yup LMC Truck has ALOT of the 60's parts. More geared to chevys though from the looks of the catalog but i've ordered parts from them before and can vouch they are pretty good quality-wise..could use bein a bit cheaper but couldn't everything? haha
Be sure to price compare before buying from LMC thumbs_up: https://www.stovebolt.com/ubbthread...;Words=caveat&Search=true#Post495922
