5 members (Hotrod Lincoln, tesa, Nick in Manitou, J Lucas, klhansen), 220 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
#704503 12/18/2010 5:30 PM
On my 49 Sub the front passenger seat has almost no foot room for an average size person. Whenever my wife goes with me to a car show or cruise she always complains that she has no place to put her feet. I think there is enough room to move the seat back 2 or 3 inches before it would hit the riser for the rear wood floor. It would just be a matter of drilling new holes in the new position and bolting it down. With it folded would there now be enough room to get into the back seats? Anybody ever try this? I am open to any other suggestions on solving this deal. She enjoys going with me and I like having her along because she is an excellent navigator and map reader.
Weeds
Weeds #704524 12/18/2010 6:32 PM
Invite her to sit beside you.
Weeds #704532 12/18/2010 7:16 PM
Y
Y Offline
On my 51 Burb the jump seat is inline with the drivers seat, so I assume yours is not? Both seats should allow for enough foot/leg room. Also the jump seat folded up still leaves plenty of room to access the rear area.
Yakimabowtie #704573 12/18/2010 10:10 PM
maybe she'd like being a "back seat navigator"? grin
I'd just try mocking up the seat move and see if it solves the problem without causing new ones
squeeze #704596 12/18/2010 11:50 PM
I asked my brother and my neighbor if they thought my suburban had enough foot room,keep in mind both these guys are over 6' tall.My brother said there was plenty of room and my neighbor said "why wouldn't there be" ? So I'm wondering where your jump seat is mounted ? Like stated above,my drivers seat and jump seat are in- line with each other.I sat in my passenger side and it seems fine with me.
Tim
1951 3100 Chevrolet
bowtietim #704740 12/19/2010 5:58 PM
My movable "70% driver's" seat can be placed in line with the "30% passenger's jump seat". There is plenty of room for a passenger's legs on the jump seat (but that seat is less comfortable than the 70% seat.
tclederman #704749 12/19/2010 6:30 PM
I have modified the 70% drivers seat using the electrics from a 70s Grand Prix. The seat is adjustable front and rearward within a 5" range and up and down probably 1" or 2". I did this mod because some of the original adjusting mechanism was missing. This along with the tilt wheel makes for a comfortable ride on long trips. The 30% passenger front seat however is bolted down solid and is not adjustable. The seat is also quite narrow and my wife is not as petite as she used to be. This along with very little foot or leg room make for an uncomfortable ride. Instead of bolting it down fast 2 or 3 inches back maybe I should be looking at some way to adjust it back and forth. Anyway I thought maybe some of you had solved this dilemma. I am 5/11 and 208 and there is no way that I could fit in the passenger seat and tolerate a long ride. I need to make it adjustable and I will figure it out sooner or later. Thanks for the replies.
Weeds
Weeds #704759 12/19/2010 6:58 PM
I ran accross this page while deciding what to do about seats for my panel. They offer a variety of parts for seats and modifications such as seat tracks. Perhaps you can find something here .
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
The Ned #704790 12/19/2010 9:46 PM
Weeds, you may have been away at the time THIS this was being discussed. Sully started THIS conversation because he had modified his passenger seat frame to tilt forward. Sully was using late model bucket seats, which is probably more comfortable than the original split seat.
I am not sure that this will work in your circumstance because you are using the original frames and seats. If you look at Sully's seat pictures you will notice that he set HIS SEAT back a couple of inches more than the original seat. The way his seat FLIPS FORWARD may allow more room than the original seat does.
Do you have a picture of your final seat location? Do your seats match up when you have the drivers seat in it's correct position?
GMONIZ #704822 12/19/2010 11:27 PM
George, looks like the Bronco bracket might work. Thanks to you other guys for the replies and suggestions. Pics show the drivers seat in the forward and back positions and the passenger seat in the normal and flipped positions. The seats do not quite line up when the drivers seat is in its most forward position.
http://picasaweb.google.com/lh/photo/q6ofuUmL65kJTuiXTdpezw?feat=directlink
Oops, wrong pic, see added post for seat pics.
Weeds
Weeds #706498 12/26/2010 8:56 PM
Weeds
I am using bucket seats from 2005 suburban. To gain extra room I moved both back so that rear of seat sits on top of the "back deck" steel lip. The steel strip is good to attach the rear bolts and then used steel 1" square tubing to level out the front. I think I gained about 3=4" leg room.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
49bourbon #707188 12/29/2010 9:40 PM
Ter Offline
Hi 49bourbon
I have been reading this with interest.
Could you post some pics of your setup that show the late model seats, and how you they tilt forward?
Ter
Ter #708037 01/02/2011 1:33 AM
Weeds, Beautiful 49 Burb!! Really nice. Looks like you spared no expense in making it a sweet driver. Congrats on a job well done.
Sorry the Mrs. is not as comfortable. I don't know anything really about the Suburbans but it seems to me that the passenger seat is mounted too far forward somehow - more forward than intended as there should be more foot room...
Good luck with it!
Professional Novice
Frank50 #708214 01/02/2011 8:18 PM
Seat arrangement on my 49 Sub. Frank50, the picture makes it look way better than it really is. Thanks for the compliment anyway.
http://picasaweb.google.com/lh/photo/dAhnHrT5GdFZ2nmfazYaNg?feat=directlink
http://picasaweb.google.com/lh/photo/wia2hxZkRtcl0tdcMnxdcw?feat=directlink
http://picasaweb.google.com/lh/photo/8OWLF41rMSJ_1IUPGCzWdA?feat=directlink
Drivers seat is electric and is adjustable back and forth and up and down. Passenger seat is not adjustable and bolted down fast. I need to figure out a way to make the passenger seat adjustable back and forth and the replies from you guys have given me a couple of ideas. Truck is put away for the winter at home so I have until April to get this done. Also need to put the headliner in and finish off the side panels. Will this thing EVER get done?
Weeds
Weeds #708315 01/03/2011 3:37 AM
Ter
Sorry been away for the holiday. Iwilltry to get some loadedin next day or so.
49bourbon #708619 01/04/2011 1:13 AM
Again, beautiful. It does look like the pass seat could go back approx 3" - if that does not crowd the first bench seat. (I guess it's in the original/factory holes?)
Also I am not familiar with the burbs and panels but the seat bottom looks deeper (longer) than a pickup seat bottom... maybe not. I like the 3-pt seat belts too.
Professional Novice
Frank50 #708901 01/04/2011 9:39 PM
From the last pic it looks like you have a seat back used as a seat cushion-it shouldn't be longer than the frame.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
64fleetside #708975 01/05/2011 1:42 AM
The seat cushion lengths look correct to me.
Tim
1951 3100 Chevrolet
bowtietim #709003 01/05/2011 4:04 AM
The leading edge of the seat in my '54 GMC sits about 3 forward of the frame. That one looks to be about the same.
Cletis #709119 01/05/2011 4:05 PM
My 64's jump seat looks identical, except the cushion is 2-3" shorter than weeds' appears-maybe a 60-66 jump seat cushion could be used? Mounts by two hooks in rear, two 5/16 bolts vertically thru front tube.
Weeds #709727 01/07/2011 2:45 PM
Guys soory for th edelay but here are pictures of the seats moved back for additional room.
http://community.webshots.com/user/49bourban
49bourbon #709733 01/07/2011 3:01 PM
64fleetside #712563 01/17/2011 5:06 AM
Guys,
Look at my photobucket. I built a custom flip and used toyota seats.Lots of room and someone 6'3" can sit on either side.
Hope this helps.
Sully
Solved the no legroom problem by drilling new holes 2 1/2" rearward and bolted the seat down. Also made new taller front brackets so the seat now tilts back a little. Seat folds forward almost the same and the cushion hits the dash in almost the same spot.
Weeds
