1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I am about to start replacing patch panels on my 41 chevy 1/2 ton. I need to do the lower cowl on both sides and both lower door skins and lower frames. My question is, which ones should I do first, should I do the doors and then match them to the cowls or do the cowls then match the doors to them? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I would do one at a time remove one replace it with the new one and make sure it fits very close to the original panel.Measure and measure again make good reference marks as you go ,take your time until you get a good system down.Hope that helps. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I understand that I need to do lots of fitting and measuring, but, where should I start, doors or cowls? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Unless you have sheetmetal flopping around in the breeze I don't think it matters. Start with the doors and fit them to the cowls then do the cowls and match them to the doors or visa-versa. A contour is a contour and as long as you don't try doing both at the same time, one remains constant. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Homer52, are you going to weld these panels in with the intention of completing the job without bondo? I ask because I did that job on my '36 Chevy pickup when I restored it in the early 70's.
If you're interested I can share what I learned.
If you're an experienced body repairman please excuse my intrusion.
Ray
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I'm going to try and do it with no bondo, I need to practice up with my tig welding on thin material before I start. I'm all ears, I would like any advice, pictures, whatever you can provide to help me. By the way this is my first try at body work, hopefully not my last. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | An old bodyman who has shared some tips with me always preached - fit everything to the doors. So...that was his advice. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Dave, if you don't mind maybe we should handle this with regular email. I actually suceeded in doing what you are going attempt working on my '36 Chevy pickup in the early 70's. What I will have to say will sound like self promotion to some but I'm not a body repair man, I'm a geologist. It's really refreshing to hear from somebody who wants to master one of the most difficult skills in the car hobby, body repair without bondo. Ray email [email protected]
Ray
| | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | I would like to read what you have to say.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Jun 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 25 | Homer52, if you could, please submit pics and lessons learned from your experience with patch panel replacement. I have a '41 3/4 ton that needs the same work done. So, I am very interested in how it works out for you. I won't be working on the body until this coming spring. BTW, do you have your panels yet? If so, where did you get them? I need both lower cowls, a driver side lower door skin, and passenger side cab corner. Hopefully that is all I will need. I won't know until I have it blasted. So, again, please keep us posted on your progress. Thanks! Dan | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Some pictures on my 4t6 body repair start here. Maybe will give you some ideas. Have fun and good luck Dan | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Dan, I got my panels from Ray Stanley, he sells to Jim Carter but you can order directly from him. Here is his e-mail address [email protected] Dave
| | | | | Joined: Jun 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 25 | Thanks a million Dave and Dan! Let us know your progress.
Dan
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | EnigmaT120, as you requested here is what I had to say about welding in patch panels. This information is offensive to some people because it conveys the clear message that bondo is for plastering, not for auto body restoration.
"Dave, welding the extremely thin sheet metal that is used in body panels is something that should be practiced on scraps before any actual body panels are welded. I have done a lot of it on my '36 pickup with oxy-acetylene equipment in the 70's because I did not have tig then.
Welding body metal causes tremendous warping and controlling that warping is the challenge. It cannot be totally eliminated, just minimized. Warping that remains when the welding is complete is removed by metal straightening and shrinking.
The welding steps are as follows:
1.Trim the pieces to be welded to a perfect fit for butt welding.
2. Place wet towels on both sides of the area to be welded to keep the panels cool outside of the weld area.
3. Make MANY very small tack welds along the seam at about 1 inch intervals. After each tack weld, cool the area with the towels.
4.Even with this many tack welds the actual weld will warp and will have to be done in short sections of a couple of inches. After welding each short section cool the weld and the whole panel.
5. When the weld is complete it will be worked with a hammer and dolly to remove the waves and irregularaties.
6. Then the whole panel will probably require work with hammers and correctly shaped dollies to restore the correct contour.
7. There will probably be some expansion of the panel that can only be removed by metal shrinking. That is a tricky procedure that I can only explain by actually demonstrating it or by making a series of sketches. I have no computer skills so I can only send the sketches on regular email after I get my wife to scan them.
What I have described above is, like so many skills, simple once you know how. But, like learning tig welding, a lot of practice is required and the first attempts are a real mess."
Ray
| | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Ray,
No offense taken here. Thanks for posting it on the forum so I could see it too. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | You are welcome Peter.
This forum is unique in that people here are interested in how to actually do these kinds of difficult tasks. I belonged to an international "Vintage" Chevy club for over 40 years and almost nobody was interested in learning the difficult to master skills like body repair without bondo, painting and mechanical tasks like setting up differntial ring gear and pinion sets. They simply "Took it to the shop" to get that done. Here on Stovebolt that kind of stuff is part of the daily discussions.
It's nice to be able to pass on what others taught me decades ago. Most important is the concept that it can be done. An old timer said to me 35+ years ago regarding body repair and painting of my '36 Chevy pickup "YOU WON'T LEARN ANY YOUNGER". If I knew how, I would post pictures here of what that 35 year old restoration looks like today to show others that a motivated amateur can indeed get 'er done.
Ray
| | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | Thanks Yar.
"1.Trim the pieces to be welded to a perfect fit for butt welding."
So you are aiming for no gap at all between the patch panel and the body? I need to practice some metal shrinking....
| | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | Thanks Yar.
So you are aiming for no gap at all between the patch panel and the body? I need to practice some metal shrinking.... Yes, you should trim the panels so they yield a no to very little gap. Since you are Tig welding, if you take the time and fit the panels right with no gap the best option is to fusion weld. Fusion weld means no filler rod. By using no filler, the warpage is far more constant and easier to correct later. | | |
