| | | Forums66 Topics128,078 Posts1,056,057 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 10 New Guy | | New Guy Joined: Mar 2009 Posts: 10 | As far as serious problems goes this is not one of them but I am having a problem removing air pockets out of my Power Steering unit. It causes as you know a horrible squeal when turning hard right or left. It is not my belt (it is tight) and I have cycled the steering wheel with the motor off countless times to try to remove the air pockets. Any Ideas....? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | | | | | | Joined: Mar 2009 Posts: 10 New Guy | | New Guy Joined: Mar 2009 Posts: 10 | I watch the pump for air bubbles so I realize that the fluid has to cover the vains... I wish it was that easy. Thanks though. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | By chance, do you have a remote resevior or one of the "ham cans"? I installed a "front runner" type set up on my crate motor 350. The p/s pump is a billet aluminum unit and much smaller than the others. The resevior is a an aluminum tube mounted on the inner fender. I get a squeak at full lock but can't get anymore fluid in the resevior. If you find an answer, please pass it on. Thanks
| | | | | Joined: Mar 2009 Posts: 10 New Guy | | New Guy Joined: Mar 2009 Posts: 10 | The Power Steering pump is a "stock" General Motors (canned ham) model. I have a friend who is much more knowledgible than myself who swears by the repeated cycling method, it has not yet worked for me. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | My old 86' 1 ton did the same thing until I added the correct amount of oil AFTER I bled the thing and got the air out. | | |
