0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
#703953 12/16/2010 5:58 PM
Y
Y Offline
On my 53 AD I welded the hood seam and left it flat. On my 54 AD I plan to weld it and build a peak down the seam. Anyone have any pointers on how best the do this? I have an old article that says a small tube welded down the center works for this? I'm thinking a 1/4" square stock might give me a sharper peak. Any input appreciated.
Yakimabowtie #704053 12/17/2010 2:06 AM
I did this too mine , used some round stock though . Got major oil canning on both hood tops , tried to heat shrink 'em out ala you tube video . That did'nt work so I used bondo glass to hide my mess ups . Hope your a better welder than I am . smile
bears 38 #704300 12/17/2010 11:23 PM
Not to sound like a smart arse but the reason you had the warpage in the first place was because the heat from the weld caused the metal to shrink. The heat shrinking only made it worse.
In addition, leaving the inner flange where the two hood pieces bolt together basically acts as a fulcrum. The best bet is to cut off the flange inch by inch and and then weld as you trim the flange away.
Currently working on custom metal and How to videos.
1949 and 1972 chevy trucks
70 chevelle SS455
Pictures of my work and projects
http://community.webshots.com/user/sevt_chevelle
