5 members (Bill Hanlon, rfs56trk, Hotrod Lincoln, Jon G, Hush), 126 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
#702897 12/12/2010 9:05 PM
My cam is pitted on the heel portion on about half the lobes and the lifters show cupping wear. Can the lifters and cam be resurfaced without loosing the hardening? Does anyone know of a source for cam regrinding; I would like to have the original grind profile. Thanks.....
Bear in mind that taking in your cam to be reground will likely require a machine to be set up for one pc. only. A cam from a FLAPS or other vendor would have been done during a production run and almost certainly will cost less. Depending of the depth of the hardening grinding it off is also a possibility.
You Tube
Call Kanter and check out their price for a 261 camshaft (it might be about $250 including the cam gear).
http://www.kanter.com/contact.aspx
I personally wouldn't have a cam reground if I could find a new one. Same with the lifters.
Too much work if there is a problem. Go with new and be done.
Call Delta cams and speak with them about it.I want to say it use to cost about $60-$80 to regrind one. delta cams
Tim
1951 3100 Chevrolet
Thanks for the Delta Cams link. A very informative site; great videos. I'll give them a call.
Will,
Please let us know the price(s).
I had my 235 cam reground for $75.00 at NIX CAMS 931-762-3977
Lawrenceburg Tn.
SlickT
Slickt #703510 12/15/2010 12:20 AM
Did you install new lifter or resurfaced? Have you run the engine and if so, how many miles so far.
I just talked to Ken at Delta Cams; $44.56 to grind my cam and $2.50 each for the lifters; total of $74.56. Cheap enough....
Will,
I installed new lifters
I have started the motor and broken in the cam and man it sounds GOOD !!! The cam was reground to 260 adv.duration 425 gross lift.
SlickT
I'm sending my cam and lifters to Delta Cams; I'm going back with the original profile of the three dot 261, After all, Arkus Duntov designed the cam and GM did the R&D.
Let me know how that reground cam works out for you over the long term. I never have had good luck with a reground cam, so won't ever use one anymore.
Remember, you get what you pay for. But I hope you have good luck.
