3 members (TS3600, klhansen, 1 invisible), 100 guests, and 2 robots.
Topics128,166
Posts1,057,012
Members48,458
I am going to put a 235 in my '36 1 1/2 ton and keep the original driveline. The 235 is about 1 1/8" shorter than the 206 and I don't see an obvious way to extend the drivetrain. I'm thinking that I will have to set the rear of the engine where it needs to go and modify the front mount too. Has anyone been down this road ? Any advice on fabricating engine mount supports would be greatly appreciated also.
Y
yar Offline
Y Offline
Dmart, does your '36 have the origiunal 2-piece fan shroud?
Ray
If you use a 1938-46 truck bell housing, it will mount to your 235 engine, stock trans, and stock bell housing mounts. You will need to extent the front mount.
My Blog
Yar, yes it has the original shroud.
Thanks Dave. That was the way that I was headed, extending the front mount. It looks to me that I will also need to fabricate new rear mounts as I don't see the original cross frame fitting between the oil pan and bell housing on the 235 as it did with the 206.
The bell housing should fit, but you will most likely need to trim the front flanges on the cross member to clear the pan, as the 235 pan extends back farther.
My Blog
That works. Thanks. I have a bunch of bell housings around so will try to find the one that will accept the original rear mounts. Any words of wisdom on how best to extend the front mount ? It looks like the bolts will be right at the rear flange of the front cross member and I'll need to remove some of that too.
