| | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | The pulley that is attached to the harmonic balanccer is damaged and needs to be replaced. I have a puller but am having problems getting the bolts that the puller pulls against started. Should these bolts be 3/8 or 5/16. This is on the original engine of a 55 3100. Any other general advice about replacing the pulley once I get the balancer off would be helpful. I think it is riveted on. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy remohbill, I think the puller bolt holes are 3/8" N.F. if I'm remembering correctly. I've never replaced a rivited on balancer pulley, so I can't comment on that. | | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | This job required 3/8 bolts, the holes were really full of gunk. Turns out the pulley was ok after all. | | |
