0 members (), 90 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
#703471 12/14/2010 9:47 PM
I need to get new door glass for both doors on my '48 ton and a half...can only find the door glass fro a 1/2 ton in the LMC catalog. I think I read that the cabs are basically the same on the big bolts and smaller trucks and of course want to know if i order the window glass and frames if it will fit right in the 1.5 ton doors...
Thank you for any help..
Steve
1948 Chevrolet 1.5-Ton Dually
More pix on Photobucket
Motoswiz
North Florida
3B Offline
Hy Motoswiz, yes the doors are the same 1/2 ton and 1 1/2 ton, hope that clarifies
Moderator
Moderator
2 Offline
Yes, the cab is the same from the Fire wall back, from 1/2-tons to 2-Tons.
Anything in front of the fire wall, below the cab and behind the cab will be different.
2-Ton
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Thanks for all the replies...I thought I had read that here on the forum but couldn't find it in the search...
Motoswiz
North Florida
Try Jim Carter Truck Parts. They have glass and/or templates to take to a local glass company to have them cut. Flat glass is easy to cut. Make absolutly sure all the window guides and seals are in good shape. Make sure all the rubber bumpers are in the door. The latch should be in very good shape and adjusted properly. No Slamming the door!
I always roll the window all the way closed so the glass is supported when shutting the door. Good Luck!
1948(10/'48) Chevrolet Loadmaster 1.5 Ton, 235cid, Muncie P211X, 137" WB, Dual Wheel Rear Axle 11,000# GVWR, Chalky Blue
I like giving advice. That way I don't have to fix it.
Motoswiz #704336 12/18/2010 1:42 AM
Double Tap
