1 members (delky), 258 guests, and 3 robots.
Topics128,089
Posts1,056,141
Members48,436
I'm trying to remove/replace the threaded spring bushings from the frame on my 57 Chevy 1/2 ton project. I have a whole set of bushing pullers and drivers, but nothing that will fit the threaded ones that are in the spring hangers. I was thinking of using one of the old threaded pins and a deep socket. Is there a tool still made for this job? Thank you.
Larry
Riding in the Passing Lane
That's the way I do them. Screw an old pin in it & wack away.
1972 Chevy c10 Cheyenne Super
Thanks. Do you use the same method to install the new ones? I was thinking it would be a good idea not to bang on the new bushings. There is a thread on the tech forum that discusses using a carriage bolt to remove them, but I don't want to distort the new ones as I install them. Thanks.
Larry
I use a balljoint/ujoint press. This works very smooth and easy to get them out and put them back in without deforming the new bushings.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
Check the tech tips - there is a good post about this subject. I made the tool described and it worked great for both removal and installation. No beatin' and bangin' - and very cheap and easy.
tcox,
Is that the one with the carriage bolt? If so yes I saw it, and I am going to try it. Thanks.
Larry
Yep - worked great for me. Good luck!!
Denny G
Sandwich, IL
I use this method with a longer bolt and a 1" pipe t to pull against with the new bushing pushing into place while removing the old one. A one step procedure. Out with the old and in with the new. It seems a little quicker. secret
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Thanks. Something else to try while I'm at it.
Larry
I like that tech tip.
When I did mine this spring, one side required heat and a BFH. Looks like Boyo ran into that as well.
