| | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I'm trying to remove/replace the threaded spring bushings from the frame on my 57 Chevy 1/2 ton project. I have a whole set of bushing pullers and drivers, but nothing that will fit the threaded ones that are in the spring hangers. I was thinking of using one of the old threaded pins and a deep socket. Is there a tool still made for this job? Thank you.
Larry | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That's the way I do them. Screw an old pin in it & wack away. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thanks. Do you use the same method to install the new ones? I was thinking it would be a good idea not to bang on the new bushings. There is a thread on the tech forum that discusses using a carriage bolt to remove them, but I don't want to distort the new ones as I install them. Thanks.
Larry | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | I use a balljoint/ujoint press. This works very smooth and easy to get them out and put them back in without deforming the new bushings. | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Check the tech tips - there is a good post about this subject. I made the tool described and it worked great for both removal and installation. No beatin' and bangin' - and very cheap and easy. | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | tcox,
Is that the one with the carriage bolt? If so yes I saw it, and I am going to try it. Thanks.
Larry | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Yep - worked great for me. Good luck!! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Oct 2009 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 136 | I use this method with a longer bolt and a 1" pipe t to pull against with the new bushing pushing into place while removing the old one. A one step procedure. Out with the old and in with the new. It seems a little quicker.  | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thanks. Something else to try while I'm at it.
Larry | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I like that tech tip.
When I did mine this spring, one side required heat and a BFH. Looks like Boyo ran into that as well. | | |
