1 members (Bill Hanlon), 48 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
What needs to be done to remove a torque tube rear end from the transmission end?
[IMG]http://i377.photobucket.com/albums/oo216/texaslocogringo/tuberemove.jpg[/IMG]
The picture above is color coded, but you can prolly figure it out with looking at the pic.
remove the 4 red bolts
slide the blue collar back
slide the green tube back
then you will se a U-joint that you undo like any other ans your done!
-LGringo
'54 chevy 3100. In pieces now. .... I've always liked puzzles
-Gig em Aggies! Class of 2013
Thank you very much.
J M Offline
Just a note of caution. When you loosen the U joint. make sure that the torque tube is restrained somehow. I always use a chain to catch it. I took one loose one time that the rear end had some pressure on it, and it came down and just missed my head. I know my head is hard, but there is no sense testing it.
Just something to think about.
Jim
Thanks for that tip, it is appreciated.
