5 members (Bill Hanlon, Patharr, Hotrod Lincoln, Brian Moore, Hush), 53 guests, and 2 robots.
Topics128,090
Posts1,056,026
Members48,432
#702519 12/11/2010 5:42 AM
Hi,
I was looking at a 1955 GMC online at C&H Truck Parts and spotted what I think are Dayton Hub adaptors. Can anyone confirm this? I'm not looking for them myself but I have read that people are interested in a set.
The Truck
http://www.candhtruck.com/chtruckdb/TruckDetails.aspx?iID=1282&iCID=9&nIDX=1&iPICN=2
Look at the rear axle
http://www.candhtruck.com/chtruckdb/bigpic.aspx?iID=1282&PICN=2
Alex
"If you can't fix it with a hammer, you've got an electrical problem."
The wheels on the steering axle and the drive axle look like what one would normally find on a 450 series GMC. Drag axles were added by cutting the back spring hanger off and hanging the equalizer on the spring. Neway was the most popular drag axle and it used a 20k trailer axle. I have never seen a drag axle like this one with a square axle. I would say that that it is some odd ball axle and the hubs fit it and nothing else. C&H is active in the salvage business, but many of the old vehicles have been sitting around for years and the people who knew a little about them have retired. This one may be a newer addition because it doesn't have trees growing through it yet.
That third axle does appear to have Dayon Wheel Adapters. Look how they resemble the rear Dayton Adaptors I have,on my GMC 470 series, on this photo I sent Grigg. http://community.webshots.com/photo/2788112110080251109FzlseX That third axle looks to be a "Truxmore Trailing Third Axle". They used a square axle like that.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Spanky, they list it as a Truxmore drag axle. It is probably a older than the truck. But I think you might be right that it is a Dayton adapter. However, I know of no way of figuring out what kind of hub was used on that square axle other than measuring the bolt circle. As far as that goes, I don't see any lug nuts where it would be bolted to the original hub.
Yeah Ken ,I had a '48 Chevy 2 ton conventional once, with one of those Truxmore setups, on it. Remembered that square axle. I didn't notice the ad with the description in it. I blew the photo up extra large, & it looks like you can see a lug nut at the lower edge of the axle. Can't tell much more from that angle.
Spanky Hardy
1950 GMC 250 1-Ton
