11 members (Gdads51, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, Peggy M, 1 invisible), 127 guests, and 1 robot.
Topics128,103
Posts1,056,183
Members48,436
I am redoing a 1946 suburban and am going with a IFS and a 350/350 setup. Are the frame widths up front the same between the 2 body styles? There is so much more available for the 47-54 than for the 41-46's and was just wondering how much of that is interchangeable.
Yes, the frame widths are the same "up front" from 37 to 54 1st Series.
I was guessing that was the case but was not sure. Does anyone know of any issues using a IFS kit listed for a 1947 and using it on a 1946?
If it's a 46 and a first series 47, there shouldn't be any problem. Second series 47 I would think would work. Ask the vendor.
Anyone else got any info? I know when looking at kits they have them for 41-46 trucks and 48-54 trucks listed seperately.
I'm running a 54 front axle under my 37. No problems. The Chevrolet part number for the front axle is a cast number that they started using in 41 and goes through 54. The difference may have to do with steering issues because even though they use the same axle, the steering is set up differently with 41-46 using one kind of box and 47 and up another. I'm using a 41-46 box on my truck. A 47-54 box will not work on my truck, but, again the axle is the same.
