6 members (TGP, Bill Hanlon, Hotrod Lincoln, greenie-reddy, 1955 1 Series, Otto Skorzeny), 178 guests, and 3 robots.
Topics128,108
Posts1,056,228
Members48,436
#70234 12/18/2006 1:56 AM
Junior Member
Junior Member
Thank you for providing this forum.
I have limited knowledge about engine identification.
I just acquired a '49 Chevy 3100 in ex cond. The engine and (automatic) trans are newer and the engine runs well, seems to be a very recent rebuild. The numbers on the pad just behind the distributor do not match anything I find on the internet regarding engine ID. Thinking it might be a Crate engine # I emailed them and no, it is not their number.
The number just behind the distributor is CE1A00343. There is a casting clock in the block and I understand that is a Saginaw marking.
I am guessing it is a 250, late 70's due to the EGR? valve on the valve cover.
any help?
thanks!
Riding in the Passing Lane
Get the casting numbers & try www.inliners.org
1972 Chevy c10 Cheyenne Super
Junior Member
Junior Member
Thanks, I have looked and so far got close to the number with a 292 and a 250 but nothing yet. I really appreciate the lead! The numbers had the 388 but not the last 4 (4257).
I am going to go all over the underneath and sides of the engine and make sure I have my numbers right.
The website below believes that the CE prefix is indeed a replacement or warranty engine.
http://www.chevy-camaro.com/chevy-camaro-engine-suffix-code-help.asp
If you can find your block casting number this list of numbers should help to identify your engine displacement as Wrenchbender suggested above.
http://clubs.hemmings.com/clubsites/chevytalk/GMhistory/6-cylindercast.html
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
I was re-reading your second post and am guessing that you found a block casting number of 3884257.
I looked a little and wonder if what you think are 8's could be 9's.
Block casting # 3994257 shows up as a 1967-72 250 with a head casting number of 3927763 or 3895052 according to this site.
(Look almost half way down the list)
http://www.butlers-a1.com/chevym.htm
Just something to think about.
Junior Member
Junior Member
I'll check it out! Thanks!
Junior Member
Junior Member
You were right! The 9's looked like 8's until I just about stood on my head in the engine compartment and studied the numbers up close.
Thanks a million.
Mystery solved.
