1 members (2-Ton),
68
Mod | | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | Does anyone have photos of a fuel tank on a 1947 or 1948 3/4 ton long bed?
Also, know where I can get a new one? I want to compare your photos to my tank to be sure it is original.
Thank you, Keith | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | Got pictures from a 1/2 ton if you like. Bowtie bits, Jim Carter, American Classic Truck Parts are a few that carry tanks, most of them galvanized. Good luck. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The Suburban gas tank is almost identical, except for the filler tube. Jim Carter sells the reproduction and lists them for both the 1947/48 Trucks and the 1947/55 Suburban/Panel/Canopy Express. | | |
