| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | I am trying to figure out if the floor cover for transmission access I have is original or homemade. Could some one measure a known orginal covers width for me and reply? Mine seems narrow and thinner gage than I think it should be. 1951 1/2 ton pick up..Thanks in advance. Lou.
1951 chevy 3100 short bed frame off resto.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Lou, it should be pretty obvious if the cover is 'factory'. The original is ribbed for strength,and has a slightly rolled edge. It should also have some type of tarboard sound proofing on the underside,mind you that may have fell off during the last 60 years! Mine was toast,one of the few panels on my truck I couldn't save. Sorry I don't have a picture. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Good Morning Denny! Two questions. Is that just regular roofing paper you formed for the seal? And, is the vacuum bag you used the type I see selling on tv for compact storage?
Drew
| | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | Thanks for the pics and help, mine is a 3 on the tree so I don't have the shifter hole and do have 3 ribs. The under side has no evidence of glue or tar, still would like width dimension if possable. Thanks! Lou
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Lou & Denny,
Lou raises a good question regarding that tar substance being under the 3-speed cover (and the Hydra-Matic cover in 54/55). It's been too long since I have seen an original 3-speed cover but I have a couple original Hydra-Matic covers (my 4-speed covers have that tar substance and my COE cover has insulation "sandwiched" between two pieces of sheet metal. Has anyone checked the Factory Assembly Manual (I will tonight)?
Drew, thanks for asking Denny about the vacuum apparatus - I am also interested in that answer.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes Drew, that’s 30# roofing paper. The original material was thicker but 30# is the heaviest felt paper that I’ve been able to find and I looked for months. No that is material that is made specifically for vacuum bagging. I learned about those materials at the last job that I had before retiring. We made a lot of very high tech carbon fiber structures used as supports for the detectors at a particle accelerator. The materials are available anywhere they sell supplies for fiber lamination. I bought a vacuum pump from a HIVAC service guy that was retiring a couple of decades ago and it comes in handy. The vacuum sheet is a very heavy plastic, yes, very much like that used for bagging cloths for storage. The sealing compound is like a strip of bubble gum and in this particular application it seal the opening of what is actually a bag that I formed.
Although the bottom of the transmission covers look like they are just tarred over I believe it is really very heavy felt paper filled heavily with tar. This felt paper material was used in different weights for all of the anti-squeak gaskets also. I just pitched out the original one that was on mine, I’d kept it for four years and no one ever asked about it.
Not real sure what your fishing for Lou, you should be able to measure the opening to get your dimensions. But the cover will be 15” x 21”. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thanks Denny. That(the vacuum bag) certainly is a novel way to partially add to the restoration of your truck(s).
Drew
