Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#701223 12/06/2010 5:50 AM
My 1952 3600 starter is beginning to turn over slower than before. It is getting real weak. Where can I find a rebuild kit for this starter? I have not had much luck finding one?
Joshua #701229 12/06/2010 6:19 AM
There are a few more components than just the starter ie cables starter relay etc. Poor connections on battery cables or small or worn out cables will really slow a starter. So will an old near end of life battery.
Check battery voltage while cranking. Should only decrease to 75% of open circuit. Check for volt drop from battery to starter solenoid and from there to starter. Check volt drop from battery to ground. Do all these while cranking BUT let starter cool for a minute or two between tests.
Dan Bentler
Joshua #701230 12/06/2010 6:20 AM
www.chevsofthe40s.com has the rebuild kits.I didn't see 12 volt but they do have 6 volt.Make sure your ground's are also very clean on all the battery cable if you haven't checked that yet?
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
webstershotrods #701238 12/06/2010 7:44 AM
Thanks guys I have been wondering about the cables being to small.
