8 members (Hotrod Lincoln, farmallb, Chip O, tclederman, Charles in CA, Otto Skorzeny, Stovebolt48, TooMany2count),
46
0
Mod | | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | My 1952 3600 starter is beginning to turn over slower than before. It is getting real weak. Where can I find a rebuild kit for this starter? I have not had much luck finding one? | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | There are a few more components than just the starter ie cables starter relay etc. Poor connections on battery cables or small or worn out cables will really slow a starter. So will an old near end of life battery.
Check battery voltage while cranking. Should only decrease to 75% of open circuit. Check for volt drop from battery to starter solenoid and from there to starter. Check volt drop from battery to ground. Do all these while cranking BUT let starter cool for a minute or two between tests.
Dan Bentler | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | www.chevsofthe40s.com has the rebuild kits.I didn't see 12 volt but they do have 6 volt.Make sure your ground's are also very clean on all the battery cable if you haven't checked that yet? | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Thanks guys I have been wondering about the cables being to small. | | |
