7 members (ShopRag, Wickedbass, Southerntruck, Gdads51, baldeagle, Otto Skorzeny, HandyAndy),
57
Mod | | | Forums66 Topics128,008 Posts1,055,285 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 21 | have the origonial 216in my 41 1/2 ton ,with todays unleaded gasses should i be thinking lead additive ? or should i do head / valve up grades ? I remember years ago doing valve seats etc with my dad in the old 390 when they banned leaded from the market,thanks guys,
Just say no to "BONDO" learn to lead, save a trade  Make something idiot proof .... and they'll make a better idiot ! some days i feel like im living proof  Schubert all things come to those who waite.. as long as they go get it .... Poppa Dave
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Lots of discussion has taken place in the past about this. I wouldn't take the head off just to replace the seats. Make sure your valves are adjusted properly and you should be fine with todays gasoline for many miles of driving. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tons of stuff on the forum about this subject. No need for it in these low performance engines. They run just fine with the pump gas alone. DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | fenderless,
Was your old 390 a Ford V-8?
| | | | | Joined: Nov 2010 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 21 | thanks guys , and TC...yes it was/ is 65 ford galixie , needs tlc and a happy home
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My brothers and I learned to drive in an old 1957 3-speed slant-six Plymouth. While we burned out the clutch in the Plymouth in 1966, my mother bought a 1964 Ford Custom (cheap, with no body trim) that had been a NC police car (for speed-traps and to catch bootleggers). That very plain looking 4-door had the full Police Interceptor package (with a special 390 Thunderbird engine). The early Little GTOs (3-deuces and a four-speed) were no match to this special 4-barrel and a police automatic transmission (that shifted into high gear at 80 mph).
Back to leaded gas: That 390 high-compression engines would now need leaded gas or hardened valve seats. As mentioned above, the 216/235/261 engines are probably OK with modern gas unless the engines are run for long continuous periods at very high RPM.
| | | | | Joined: Nov 2010 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 21 | great memorys T C , My galixie has the same 390 t-birdy with a c6 juice box pass every thing but a fuel pump  , thanks for thin info on the lead amd ill keep it in mind to put a little additive in if i do the long haul road trip at speed :P
