0 members (), 163 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
#700946 12/05/2010 2:10 AM
Geezer
Geezer
Today when we pulled the cab off, we were thinking about eliminating the shackels & replacing them with later technology body bushings...
I would like to know if anyone has done this, if this is a good idea or if anyone sells a kit to do the cab to chassis in a better way than the original?????
I would appreciate all input & ideas..
tC
1966 C20 LWB, 327 4 Bbl., 4 Speed
3B Offline
Hy Thirdcoast, please try to remember when you ask a question, to tell us the year and size of truck you're asking about. A little detective work tells me you have a 49 to 55 first series truck, is that correct? I have not seen a kit to change the cab mounting system, but someone else may have.
3B #700956 12/05/2010 2:37 AM
Geezer
Geezer
So Solly,
1954 AD 3100
You have to remember that I am OLD & my memory fades after a day of ONE MORE HOTROD.. & beeeeerrrrrr....
thanks,
TC
What needs to be "improved"?
I've not heard of anyone changing out the rear shackle mounts,but I suppose you could replace the shackle bushes with urethane style ones.
But as Cletis mentions why 'improve' it,they've worked well for 60 odd years......
If you rebuilt what's there with new rubber bushes,they will probably last for another few decades.
The only other problem I could see would be increased noise transmission as the urethane is obviously much firmer than the original rubber.
Something I discovered when using urethane engine mounts.....
More pix on Flickr.
Geezer
Geezer
Thanks, I will use the shackles...
TC
I decided to replace the rubber in the shackles and found when removed they were in near perfect shape. Sixty years were good to them. If it feels better then replace the rubber or not...
~Jim
Mine were like Bakelite! ohwell
More pix on Flickr.
Must be that Scottish climate. grin
~Jim
They were probably frozen! brrrrr
More pix on Flickr.
Superior Glass Works -www.superiorglassworks.com - now makes a replacement rear shackle kit if your Bakelite bushings need replacement.
