| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | If I got the numbers off my 250 engine. How do I find out what year it is? Also where do I find the numbers? thanks mark | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The numbers that will give you the most information are stamped on the distributor pad. Clean the distributor pad good and check the numbers on this web site; http://no25.chuckthetruck.com/page3.htmlThere is a casting number on the side of the block and you can check that here; http://inliners.org/Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | the number on the distributer pad is F0801TE
the casting number is 3921968 also a couple of other numbers. its a 250 but not sure what year. a casting number 00N2 another one says G287 | | |
