9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman), 93 guests, and 2 robots.
Topics128,069
Posts1,055,886
Members48,428
#701088 12/05/2010 6:01 PM
If I got the numbers off my 250 engine. How do I find out what year it is? Also where do I find the numbers? thanks mark
The numbers that will give you the most information are stamped on the distributor pad. Clean the distributor pad good and check the numbers on this web site;
http://no25.chuckthetruck.com/page3.html
There is a casting number on the side of the block and you can check that here;
http://inliners.org/
Larry
I don't own a vehicle that isn't old enough to drink.
the number on the distributer pad is F0801TE
the casting number is 3921968 also a couple of other numbers. its a 250 but not sure what year.
a casting number 00N2
another one says G287
