3 members (homer52, Bill Hanlon, 1 invisible),
140
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Can I take a voltage regulator from a 54 chevy Belair (think it is 12v) and use it in my 48 Chevy truck which is 6v? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No, a 12V regulator will not work on a 6V system. | | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Is there a way to tell if it is a 12v regulator? | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | I think 54 cars were still 6v. Didnt change til 55. If you have the reg. off,it will be stamped either in black ink or into the case somewhere on the regulator. Look around the outer flanges. | | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Arent they stamped with date codes? How do I decipher it? What happened was I bought a bunch of used parts that were for a 54 chevy Bel Air that the guy already sold. I looked today and both of the generators I got say 12v on them....I thought the 54 was 6v also. | | |
