3 members (Guitplayer, GMCJammer51, 51 3804), 153 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#700704 12/04/2010 5:17 AM
I am replacing the lower 8 inches of my doors on my TF. Anyone who has done this, do you have any tips on doing this? Any pitfalls to watch out for?
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Alan, the only thing I would do is fit the doors to the cab and gap them well before welding anything.....
I might even be tempted to tack weld the door to the cab,due to the fact you're disturbing the lower hinge.
Once you're happy with the panel fit and have tacked the repair panels in,remove the doors to finish welding.
It's the only advice I can think of as you obviously know what you're doing judging by your build pics.
Just remember the old adage, measure twice...cut once!
If you approach this as efficiently as you did the roof,I'm sure you'll be fine.
Good luck. thumbs_up
More pix on Flickr.
Thanks John, I was thinking pretty much the same thing about fitting the door to the opening. The lower hinge actually will still bolt to the inside of the door with the outer panel removed. That may give me all I need to align the hinge opening on the new panel to the opening. Its all trial & error anyway I guess.
I should have looked closer,it's good you don't have to disturb the lower hinge.
I learned the hard way Alan, in my 'formative years' I repaired a VW Beetle door and it was a mess to say the least!
I eventually gave up and replaced the door as I was sick of the lower edge seal catching on the running board rubber.
What was that, measure twice,cut once?
Still,as they say,you learn by your mistakes! wink
More pix on Flickr.
