1 members (CuzzFuzz), 101 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#700408 12/03/2010 3:03 AM
I've cleaned and reassembled a vintage Carter W-1 for my '41 Chevy 1/2 ton. The metering rod slides into a brass plug at the bottom of the bowl. My question: Isn't there suppose to be a little ball bearing that goes in there, or am I bonkers?
Y
Y Offline
I do not remember any loose ball bearings in mine, Just the seat and the rod, it is only for metering, not for shutoff. The float controls the level.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
The 'plug' is the main jet. The rod comes up under low vacuum or open throttle to increase fuel under load. If there are any check balls they would be in the inlet and maybe the outlet of the accelerator pump passages.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
Carburetion specialist
As stated by Joe in the previous post, the "plug" is the main metering jet.
While it is impossible to know what Dr. Goodpliers (the evil twin of Mr. Goodwrench) may have put in any carburetor; Carter built the type W-1 without the use of loose check balls. The inlet and outlet check valves for the accelerator pump are encapsulated balls or wafers. These valves screw into the pump column which connects the accelerator pump well with the pump jet.
Jon.
The Carburetor Shop
