0 members (),
116
0
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Been looking for that thread where there was a discussion on how to disconnect the diaphragm from the link on an AC fuel pump rebuild. Anyone remember that????
Denny Graham Sandwihc, L
Denny G Sandwich, IL
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Last time I had one a part was a while ago, but don't remember any troubles or confusion, or needing any help?
Do you have a picture of the issue? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think I used a punch and took the pin out of the main body that holds the pump arm in place. Then I think I was able to disconnect it from the diaphragm. Don | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It was simple Grig, just wasn't sure how the stem was atteched to the link. I hadn't really taken a good lool at it, I was just preping for it. All you have to do is hold the arm while pushing down on the diaphragm and kick the stem back out of the link. Simple!!!! Now, I have to finger out the inlet and out let seals or valves. I gotta get a kit to see just what new parts comes in it before I try to pop them out. Don't know if I'll have to use the old retainers or not.
No need to pop the pin out or remove the arm Don.
Denny Graham Sandwich, IL
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Denny, when I did mine I was concerned about tearing the diaphragm. I was looking at a spare in the parts box and agree removing the pin can be avoided. I guess another point would be how much grime is in the arm area of the housing for cleaning purposes. Its like many things, many different roads to the destination and everyone likes to look at different scenery. Thanks for all the great info. Don
| | | | | Joined: Jul 2010 Posts: 16 New Guy | | New Guy Joined: Jul 2010 Posts: 16 | I'm in the process of rebuilding the fuel pump for my 1941 Chevy, and was having some troubling removing the diaphragm from the link. Pushing down on the diaphragm and away from the rocker arm side of the pump, without allowing it to swing or pivot did the trick. | | |
