0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | hey guys i haven't been on for awhile but i have a question about the original H/L switch on 3100's this has now happened 2 to 3 times where the entire lighting system has shut down. the only common denominator to my truck is the H/L switch. no fuse was blown, the H/L's work off two relays thru the foot switch. the tail lamps work thru a separate fuse. everything works thru the original switch. after she got home using the fog lights, which run thru a relay and a new CH separate switch, i walked out and saw no lights and so off to the shop to grab my VOM. when I got back to the truck the H/L's worked. this tells me something inside the switch got hot and ? shorted ? or the ? paper insulation ..... if there is anything like that inside got funky and shorted and ALL shut down. I'm more interested in reliability than originality. but The original H/L switch I believe is failing. question Is it rebuildable? Are the repops any good? but i probably won't get one or a Cole-Hersee switch? . I'm leaning towards the CH switch for reliability for Caroline's safety. http://www.colehersee.com/products> switches > Head Lamp Rotary & Fuel Tank part # 71016-01 has an 11 ohm rheostat dimmer 71042 has an 7.0 ohm rheostat dimmer 7178 has an 3.75 ohm rheostat dimmer Which ohm rheostat works for our trucks??? thanks guys
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I don't know what truck you have, but on the Task Force headlight switches there is a metallic contact/point type arrangement that acts as a fuse. After "cool-down," the contacts "make" again and everything works as before. Sometimes the contact points get corroded and just need to be burnished. Sometimes they get distorted over time and you can re-bend them. For peace-of-mind a new one may be best, but I did have a new fail on me once. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | As Don mentioned Jim, the original HL switch has a bi-metal contact on top that will open if to much current is being drawn. If you have poor grouinds, that is, to much resistance or if you have added something like extra lights or halogin you may be triping the contact. If the come back on after a few minutes then that's a good indication that's where your problem lies. The original switch has brass contacts inside and they also get burned. To open them up and remake the contacts is very labor intensive. The good repop switch is almost an exact copy of the original switch and they are only about forty bucks. http://www.classicparts.com/1947-54-Headlamp-Switch-Original-Type-6-Volt/productinfo/53-111A/ Stay away from the cheaper ones they look like they are made from old beer cans. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | In that case I'd guess that the contacts are worn on the inside of the switch Jim. The contacts are like the head of a rivet, the sweged end is what you see out side fastening the terminal strips to the phenolic board. Then there is a slider once the grease has dried up both of them start to wear. I would direct you to my old Webshots album but I don't remember how to get there. I had pictures of the whole rebuilding process of the stock AD light switches. Denny Graham Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I would direct you to my old Webshots album but I don't remember how to get there. I had pictures of the whole rebuilding process of the stock AD light switches. Denny Graham Sandwich, IL Is this it? click Good Luck | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | thanks Denny, i remember that link as well as some others. GREAT WORK as usual. i had thought either you or Stu would have answered my querie btw where is the Stu? i think i have a link saved to your site but it will take me some time to remember how. hey, whats ya know, Denny: GV had a link. I don't think it's the complete one denny had when he rebuilt his and took shots and a how to DIY now what you can do Den is add this link to your profile at the bottom like i did w/ ''lucinda bolt'' http://rides.webshots.com/album/555161678EhIoCbhttp://rides.webshots.com/album/555161678EhIoCb?start=84http://community.webshots.com/user/dgraham12thanks dad BUT NOBODY has answered my original question What OHM RHEOSTAT ????
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's it Gus, lost my confuser a years or so back and during the rebuild I just decided it was time to get away from all that advertising and went to the pbase album. I wish I could transfer all those hundreds of pics over to pbase but I have no idea how to do it and to locate and reload them all would be a monumental undertaking. God knows I have enough projects going. Yeah, I book marked them Jim, lost my old favorites folder also during the crash, I'm real bad about back up. I can't help you out with the question, once you drift away from the stock stuff it gets to be like a ball of string that's unraveled. There are just to many variables for me when you start hot rodding. Thanks Dad, Denny Graham Sandwich, IL
