I nned a vendor where I can get tubing to replace my steering column mast shaft? I need it 1.75" id (max) and 1.5" id (min) so I can use the CPP 1.5" Steering Column Saver kit like done in the artical Dirty Thirty.
Second, is there a difference in diameter of te 46' vs 47' steering column shaft?
Brett
