Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Crimson48, TUTS 59, Phak1, Gdads51, 1 invisible), 48 guests, and 0 robots.
Topics128,007
Posts1,055,278
Members48,418
#69986 12/13/2006 11:33 PM
First I'd like to say how much I'm enjoying this site.
Having driven my truck all last summer I had never had it over 60mph.The last weekend before parking for the winter,I drove it up to 65-70.There was a vibation.I'll list what work that was already done to it before I noticed it
front clip is 72 Nova -all parts ok
tires are new and balanced,wheels are not bent
drive shaft has been balanced
This vibration was not in the steering wheel it was in the seat.I think that indicates something in the back.Any ideas that I can look for would be great.Thanks, Boyd
#69987 12/13/2006 11:37 PM
Riding in the Passing Lane
The driveshaft u-joint angles may be wrong from changing suspension.
1972 Chevy c10 Cheyenne Super
#69988 12/14/2006 12:12 AM
BC52,
The vibration in the seat sure would indicate something in the rear of the truck.
The rear tires would be the obvious first choice, and easy to troubleshoot...put them on the front.
My money is on the drive shaft. Many times the urge to go the 'homemade' route is too strong, and whoever built the truck had his friend with the big lathe do the work.
If you think this is what it might be, you can use a couple of large hose clamps and do a "okie" balance job on the drive shaft yourself.
I can explain the balancing deal if you think it might help..or maybe you know it already.
Stuart
#69989 12/15/2006 12:49 PM
Sounds like drive shaft problem.Had 55 chevy pickup greesed by service station once.While raising truck it was to far forward on lift and when lift came up it hit on the drive shaft puting a very small demple in the shaft. Vibration would start at around 45MPH. Keep us posted.
#69990 12/16/2006 3:37 PM
I spent a long time chasing down a slight vibration at 65 MPH. After exhausting all possibilites except new tires, I tried Dynabeads.
Worked great!
http://www.innovativebalancing.com/gallery1.htm
#69991 03/12/2007 8:02 PM
Update,I took the rear wheeels back to the tire store,and told them the problem.They did it again, just got back from a freeway drive.NO VIBRATION grin grin
